strong exhaust smell
Old 10-16-2012, 09:45 AM
me 2's Avatar
Default strong exhaust smell
I have a very strong exhaust smell and wondered what it could be. I swapped a motor out that was leaking coolant through. I have had to replace all the o2 sensors since but have not replaced the 2 downstream yet. Are my cats fried?
Old 10-16-2012, 10:06 AM
How many miles on the donor engine, do you have any fault codes, did you install new wires and plugs in it and what octane gas are you burning.
Old 10-17-2012, 07:30 AM
me 2's Avatar
Default stuff
Whats up Mike? I was told 88k on the newer motor. The only codes I get are the 2 downstream o2's. I have new wires and plugs and use 93.
Old 10-17-2012, 09:15 AM
Give me the fault code numbers.
Old 10-20-2012, 01:31 PM
me 2's Avatar
Default stuff
I will get out there and get them again. It was a couple for each o2 sensor.
Old 10-22-2012, 12:15 AM
mx468's Avatar
Are you leaking any oil? I had an exhaust smell and it was my front crank seal leaking and blowing back oil onto my headers and exhaust pipes and I had the same smell. I used blue devil recently and will post my results.
Old 10-22-2012, 05:26 AM
If you have 02 issues your exhaust will smell so replace them.
Old 10-22-2012, 07:47 AM
me 2's Avatar
Default stuff
So if the downstream o2 sensors are bad ill get a strong smell from the exhaust? How does that work? I plan on swapping both out but have to wait for that extra cash right now.
Old 10-22-2012, 09:41 AM
If you would have given us the fault code numbers it would have helped but if the 02's are bad you will either run too rich or leaning, hence the smell.
Old 10-23-2012, 07:10 AM
me 2's Avatar
Default stuff
Im working on the fault codes, gotta run by a friends to get the code reader again. Should be this week Mike.
Quick Reply: strong exhaust smell
