sudden oil leak
My Land Rover has developed an oil leak, it has lost 1-2 quarts of oil in the last 2k miles. Their were no oil leaks present when I did the oil change 2k miles ago. I got under the truck today an found that the oil is coming from an oil line fitting that goes into the engine block right above the oil filter. I would like to know if it is a common problem and if their is a way of repairing it without having to replace the oil line. I don't think the fitting is loose, maybe I can loosen it up and use some type of sealant. Any advise would be greatly appreciated.
That's the oil cooler hose, the fitting has an O ring and maybe that is shot. Replace the O ring and see if that solves it.
Thanks for the quick reply Bundu. I will check that out tomorrow. I am hoping it's the o ring and not the line. :rolleyes:
On the positive side, the oil will coat the bottom of the truck and help stop rust. You will also be keeping fresh oil in it so it is almost like changing the oil as you drive.......Phil
Originally Posted by ljdiscovery
(Post 222871)
You didn't happen to switch-over to a synthetic oil, did you?
Originally Posted by coors
(Post 222878)
Originally Posted by buick215
(Post 222879)
No, I actually went from Mobil 1 10w 30 synthetic to Rotella 15w 40 conventional.
This is the o ring http://www.roverparts.com/Parts/ESR1594L.cfm
Check with a local dealer, they are cheap enough to get at the dealer and then you should get the right part. |
Originally Posted by Bundu
(Post 222917)
