Suddenly bad radio reception
Have never been into the radio head so I’m thinking that’s probably not the case. Am I misreading the three ??? as sarcasm?
reason for the question was to see if there was a common age related failure that happens to these vehicles. Such as an antenna soldered joint etc.
No common age related issues that i know of... But do check the button connector on the back cargo area passenger side window at the top, right below the amplifier. Some models with the high end sound system have two amplifiers, the FM one being separate on the drivers side rear cargo area window... I don't have that but my window still has the embedded antenna and button, just nothing connected to it. Check both.
I've also had the antenna cable issue in that I have an aftermarket head unit and the antenna cable has more of a bend to it due to depth, I've had loss of signal but most notably on the AM band. Straightening out that cable and reinserting it into the head unit fixed it.
If none of that works check the amplifier itself, it has a ground wire attached near where it is mounted. Make sure that is connected too. You can access the amp by just lifting up that portion of the headliner below the alpine window.
Perfect Dave thanks so much for the detailed info. I’ll check both amp and button sides under the headliner
bcolins
07-05-2011 08:30 AM
