Sunroof leak drain tube leak fix
3 Attachment(s)
So I got the usual and common leak on my disco2. And my headliner was sagging down so i decided to remove the headliner to restore it and fix my water leak. 2 birds with one stone type of thing. Well after the removal of the headliner. I saw my water leak immediately. All this time one of the drain tubes were broken off the sunroof. My hose was just hanging out of place. So I broke the other one to fix it as well. I went to home depot and bought some rubber tubes that I bumped into while searching at the store for a solution.
Below I attached pictures of the outcome ( a little messy but it worked) and the parts I used and the actual packaging it came in. DO NOT CUT BACK END OF RUBBER PIECE IT WILL FIT INTO THE SUNROOF HOLE IF SQUEEZED IN RIGHT AND PATIENTLY. ITLL SEAL BETTER THRU THE INSIDE OF THE SUNROOF I used regular black automotive silicone to fill the open trims and seal the edges. GOOD LUCK PM OR EMAIL ME FOR QUESTIONS JUERGEN33911@GMAIL.COM |
