Sunroof leak drain tube leak fix
Old Jun 19, 2013 | 12:49 PM
Juergen33911's Avatar
Default Sunroof leak drain tube leak fix
So I got the usual and common leak on my disco2. And my headliner was sagging down so i decided to remove the headliner to restore it and fix my water leak. 2 birds with one stone type of thing. Well after the removal of the headliner. I saw my water leak immediately. All this time one of the drain tubes were broken off the sunroof. My hose was just hanging out of place. So I broke the other one to fix it as well. I went to home depot and bought some rubber tubes that I bumped into while searching at the store for a solution.
Below I attached pictures of the outcome ( a little messy but it worked) and the parts I used and the actual packaging it came in. DO NOT CUT BACK END OF RUBBER PIECE IT WILL FIT INTO THE SUNROOF HOLE IF SQUEEZED IN RIGHT AND PATIENTLY. ITLL SEAL BETTER THRU THE INSIDE OF THE SUNROOF
I used regular black automotive silicone to fill the open trims and seal the edges.
GOOD LUCK
PM OR EMAIL ME FOR QUESTIONS JUERGEN33911@GMAIL.COM
Attached Thumbnails Sunroof leak drain tube leak fix-20130619_125809.jpg   Sunroof leak drain tube leak fix-20130619_125631.jpg   Sunroof leak drain tube leak fix-20130619_125657.jpg
aftermath431
Jul 13, 2024 12:40 PM
Quinten
Oct 25, 2012 09:00 AM
BigRed98
Jun 21, 2010 12:30 AM
mburnett
Jun 5, 2008 09:18 PM
mburnett
Mar 21, 2008 11:38 AM
