Supercharger and turbocharger
Can't say anything about it being legal or not where ever You are located.
Contact alive tuning and they will help You out.
I am in no affiliate with them, and not even their customer, I have a TD5Inside map on my TD5.
The ZF4HP22 can handle up to 295 lb-ft of torque and the ZF4HP24 can handle up to 331 lb-ft of torque. That will be your max power target before you have to upgrade all kinds of driveline things. If you have a manual transmission, check the max torque for it. I know the autos because I looked it up before starting my LS swap.
Adding a supercharger on top of a turbo is complex and expensive. This engine / driveline setup isn't a good candidate for it. Adding power = intrusive, labor intensive & expensive.
Last edited by L33DiscoII; 02-24-2023 at 12:39 PM. Reason: weird HTML code got in my post.
Does anyone know how to get thick brake dust build up off of wheel rims? I have spent about 3 hours trying to scrub them with car shampoo and a scrub. I tried the pressure washer but that didn’t do anything. It’s a really slow process and the the bits near the back don’t seem to come off. Any idea what would help to get it off? Thanks.
