TDC? and lots of work
Ok... have decided to do some work to this '94 Disco. w/ 3.9
I would like to post some pictures of the progress and jobs if I may?
Also will post a picture when I have a question.
This site is like an online Land Rover consultancy!
What started out as a new water pump has turned into:
New water pump
Re-cored radiator
New hoses
New main cover gasket
New intake mani gasket
New valve cover gaskets
Trans filrter and fluid change
All other liquids
Even a new clock bulb!
Need to remove the flywheel to get at the main cover.
Will try to put a socket into a hard pipe wedged against the concreet floor or frame, and flip the motor for a second.
Now this may seem stupid... but prior to removing the flywheel the RAVE says to place the motor so that number 8 is at TDC. I am used to seeing several marks on a fly wheel. The rover just has a slot which I assume will be TDC.
This is in the picture below... when the timing mark is aligned with the center of the slot... on a rover is that TDC? If so, is each edge of the slot plus or minus 5 degrees?, 1 degree???
Thanks
Joe
[IMG]local://upfiles/11619/B0C81ADBE37C4E56B2D8133F54ADCB11.jpg[/IMG]
New water pump
Re-cored radiator
New hoses
All other liquids
Thanks
Joe
mdt9987
03-23-2019 06:03 PM
