Temperature switch
Truck warms up fine, stays in normal operation range on the dash gauge. Only reason I know about it is from the OBD codes. The Sender to the panel gauge is a different unit. I don't know if the acutal unit is a sender or a switch. Its refered to as both in different documentation.
Secondly, where the ?#@$%@ is it?
The parts guide shows it either on the theromstat housing on early models and a vague indication of it being on the upper right side of the engine on the later models. I'm starting to think it buried under the intake manifold .....
Cheers,
Cheers,
Is that true? I was always under the impression that the thermostats main purpose was to help the engine warm-up quicker and once the threshold was reached, it would open and allow coolant to flow throught the system....especially helpful in the winter months.
I would guess that if a thermostat was stuck open that the truck would warm up to operating temperatures, it would just take longer to do so...right? Maybe I missed this class in autoshop.
![Big Grin](https://landroverforums.com/forum/images/smilies/lxvR5hR.png)
Cheers,
Cheers,
Unstable- if the t-stat is open, it takes longer to warm up the engine, thus keeping it outside of the threshold to go to full closed loop. In the winter, your vehicle will never reach operating temp on the highway. This is possible in warmer weather as well, but it will get up there when at a stop. It will not maintain a constant operating temp, thus kicking the fault and killing your valvetrain over time.
abran
08-05-2014 06:13 PM
AZRover
07-02-2012 06:43 PM
