Three amigos won't go
Be like me and continue to be pissed off that they came back on after unhooking the batter jus tot install a new battery tray. F&$@ing stupid.
Sorry, that was unproductive, but take solace in that you are not alone.
The only productive thing I can add is that you would need to do the solder in type of sensor and according to GBR, have to get some hot rod expensive brand.
Mando (05-12-2017)
Originally Posted by Mando
I changed the shuttle valve, computer said I need right rear abs sensor so I did the whole hub assembly, I drove without the lights for a little while and the lights came back on. What's next? Pissed off
You say you change the shuttle valve. Does that mean you had a shuttle valve fault, or you just took a stab in the dark?
Does the truck have a shuttle valve code now? If so it's time for the Option B bypass. The printed circuit problem that can lead to a shuttle valve fault being detected is unfortunately not solved by a new shuttle valve. It is solved by the Option B bypass.
x2
on option b and haven't had a lick of trouble. My fault was originally a shuttle valve failure and replaced with a new one and they still came on. I didn't have any fluid on the shuttle valve so I knew it wasn't leaking and it was computer related so option b fixed me right up
I've written this before here, as have others, but the word "bypass" in the Option B description can be misleading. It's not the ABS/traction control/hill descent control system that is being bypassed, it is only a failed solder joint buried deep within the modulator body that is being bypassed. FULL ABS, etc. function is not bypassed, it is restored.
Well said mln. And yep I knew that to be the case. However, mine has come on again for some BS reason. I decided to finally put in a new battery tray a while back and when I disconnected the battery the damn Amigos came back. I think it's a wheel speed sensor, but just a stupid PITA from a total $h!t system. Man, if my wife's RRS pulled that crap, it would be gone the next day.
I need to get the full on scanner to read which sensor it is and go from there.
