Time for...
Time for...
...brake pads.
Well after 3 years and 40,000 miles my truck is finally due for new brake pads.
My wifes car is out of service as of today so the truck had to step up to #1 car status and after driving across town in heavy traffic and back the brakes started to squeal.
Once we got home took out my flashlight and took a peak and sure enough...I will be changing the pads this weekend after church.
Well, the good news is the pads are easy. Maybe the easiest thing to do. Make sure to open the bleed screw when you push the caliper back so you don't push all of the junk back up the line.
If you are going local, I will say that I tried the pads from Autozone and they are noisy and dusty. They also wear out fast. I used a lot of squeal stop on the backs too. I would suggest you use it as well. You have to wait for it to cure, but it is worth the wait.
