Tire Pressure for 255/70-16
Hi Guys,
I got the General Grabbers in size 255/70-16 and put in OME 751 springs, new OME HD shocks all around and spacers in the rear for my SLS. I have a few questions...
Is the reccomended tire pressure the same for oversized tires?
I haven't run through a full tank of gas yet, but it seems to be A LOT worse now.
I flushed the coolant last week, and Monday I blew the bleeder screw out. I got the new style upper hose and bled the system. I filled the coolant tank and now it's about an inch or more lower. Is this normal after a flush? Does it take a while for the coolant to remain level? I haven't noticed any leaks since I got the new hose, temp is normal and there is no coolant in the oil.
With all these changes to the truck I am probably being more attentive than before and noticing things that are probalbly fine.
Thanks for the replys!
RE: Tire Pressure for 255/70-16
It can take several cold-hot-cold cycles to fully bleed the cooling system. Just check it every morning until it stays full. Should only take 2 maybe 3 days. Anymore than that and you have a problem.
Yes oversized tires can reduce your mpg. More weight = less mpg. Shouldnt make a huge difference though.
As far as psi, tire size makes no difference. You can run what you were before.
The tire pressure can effect your MPG pretty badly. I was looking at those tires a couple of weeks ago and I beleive that they are only a 44psi rated tire so dont go over that but go as close to that as possible. Remember that the higher you pump them up the more stiff the ride is going to be so its really up to you (mpg vs comfort). I run 55psi on all four with BFG's in that same size but they are a 60psi rated tire. Works for me. Your mileage will go down with the new tires but it should only be in the 1mpg range. Hope that helps
