Tire Pressure Question??
Does anyone know why Land Rover has you running 30PSI on the front tire and 46psi in the rear?
You would think you'd want more pressure in those front tires to support the heavier front load. I would also think that if you had more pressure you may have less wear. Ride quality may suffer so this could be the ticket.
Any thought,theory's or data on this???
Max Load is 30psi front and 46psi back. Makes sense as I'm guessing this refers to towing.
Thanks for directing down the right path.
