Too Cool for School...
I'm having an unusual problem with My 02 Disco that I cant seem to find any answers to. We are getting into the winter here in Ohio, with the average daily temp being between 30 and 50 degrees, and I've noticed my truck running extremely cool according to the temp gage which barely rises above the blue zone. Curious about the accuracy of the gage, I checked the engine temp at the radiator and at the block with a laser thermometer and recorded temps in the 80s and 90s. Not much heat coming out of vents either. Just serviced the cooling system about 20k ago, including a new thermostat from AB. Also the radiator was replaced about 15k ago. Any Ideas???
Even with a stuck thermostat, 90º is damn cold after driving for some time.
Depends on the condition of the cooling system and what t-stat you are running, but usually between 190 - 212. When I was running a factory stat I would usually run 195ish on the highway, and about 200-204 around town, with my warm idle spiking to 212 every once in a while. Now that I am running the motorad 180 t-stat I am about 188-190 on the freeway, 194 around town, and my warm idle spiking to 200 once in a while.
It could be. You can always pull it out and test it by putting it in a pot of water, use a thermometer to measure water temp, and heat the water and see when the stat opens and then turn off the heat to see if it closes properly.
Joseph David
03-14-2011 04:04 AM
flavorking
02-10-2008 12:33 PM
