Engine rebuild
The goal is to bring the engine to a reliable state capable of daily driver duties and family outings. Yes, the head gasket is one of the items that will be replaced along with resurfacing the heads and doing a valve job. Would you suggest that I replaced any other components? Other parts for replacement are listed below.
Radiator Water pump Thermostat (low temp variation)
Originally Posted by drowssap
(Post 506049)
what is your ultimate goal here to replace the heads gasket?
You want reliable daily driver..... all aluminum radiator, in line thermo mod, electric fan.
Originally Posted by dgi 07
(Post 506198)
meaning get rid of the bypass and put a traditional stat in an inline housing
Help
I have managed to strip the head bolt on the passenger side closest to the firewall (the pain in the *** one to remove). I'm afraid I stripped it pretty good using a 1/4 inch 5/8 socket and a huge breaker bar, with a wobble extension. Not sure how to address this new issue, any takers? (video to come soon)
I'm thinking about trying one of these to remove it
Upon removal,Did you start with that bolt?
You should have, but if not put some others back to relieve pressure, then use whatever striped out nut tool. That ^ thing looks promising |
as stated before you should un-torque the head, working from the outside in. But as stated install some bolts and snug them down then hammer a 6 point metric socket onto the head bolt and remove it.
Removing head bolts
(Post 506979)
http://c.shld.net/rpx/i/s/pi/mp/2074...6&op_sharpen=1 This thing took the head bolt rite off! |
Turbo socket?
I don't see the compressor...and where do the exhaust gases enter?
