Torgue Converter Seal Leak 03 disco
Old 09-21-2009, 03:52 PM
dgm's Avatar
dgm
dgm is offline
Default Torgue Converter Seal Leak 03 disco
Got a leak on the rearward seal of the torgue converter. At higher speeds the fluid hits the HOT muffler and sprays on the rear window. Is this an easy fix, I mean for someone with moderate mechanical skills? If I cannot get it changed, could I top it off before a short trip? If so where to top off? It only leaks at high speeds, daily driving is OK... Also I will be changing oil soon, what do you recommend for SC weather Mobil 1 10-40 with a Mobil 1- 301 filter? Advance has the 6 quarts of Mobil One on sale with your choice of Mobil one filter for 29.99 until Sept. 30th.
Old 09-21-2009, 04:11 PM
How do you know it is the torque converter leaking and not something else?
Lots of things under the truck to leak.
Old 09-22-2009, 07:57 AM
dgm's Avatar
dgm
dgm is offline
The fluid is coming from the rear seal, not above, or in front of.
Old 09-22-2009, 08:50 AM
You will not want to take your Disco on a trip if you have a pressure seal leaking. No, you won't want to remove the tranny and it should go to a tranny shop to be looked at.
The 10W/40 will be OK in your area, unless you get into a lot of 20 degree mornings then I would suggest 10W/30.
Old 09-22-2009, 06:19 PM
The bottom number on motor oil is how well it pumps when cold, so 10w-30 and 10w-40 will pump at the same rate when cold but 10w-40 will give better protection when hot that 10w-30 will.
http://www.carbibles.com/engineoil_bible.html
EstorilM
05-08-2022 12:39 AM
outdoor7or24
05-21-2012 08:34 AM
fj60disco
05-18-2010 10:34 PM
yloDiscoII
02-10-2010 10:03 PM
Smorgan2004
05-28-2007 06:50 PM
Quick Reply: Torgue Converter Seal Leak 03 disco
