Torque App for Android Review
Old Dec 11, 2015 | 08:58 AM
  #21
Charlie_V's Avatar
Originally Posted by evoblade
Is oil pressure available for measuring/graphing or is the oil pressure sender just there to run the dummy light?
Mine is a dummy light only. There are two different pressure switches, and they have different threads and connectors. Mine is the old one with larger threads and a single blade connector. The other has a smaller threads and a plastic connector that goes over the end of the switch. Mine is dummy light only and I'm pretty sure the other one is too.
Old Dec 1, 2016 | 10:27 PM
  #22
Patrick Danforth's Avatar
4th Gear
Default SAM Note 4 ECU error
Originally Posted by 2003DiscoAZ
Samsung Note 4
ELM 327 Elm 327 Interface Bluetooth OBD2 OBD II Car Diagnostic Auto Scanner Scan eBay
Torque Pro, connects to the dongle but not to the ecu
I JUST UNPLUG THE UNIT A FEW TIMES TIL IT CONNECTS AFTER CYCLING AND RE-ENTERING THE CONNECT CODE 1234 factory setting. Sometimes restarting the truck works as well with unit plugged in.
Old Jul 10, 2019 | 07:47 AM
  #23
Di Sanders's Avatar
Have you had any responses to this query? I have the same problem using the Viecar 4.0 OBD2 on Land Rover Defender td5 2007. Help!!
Old Nov 27, 2020 | 09:06 AM
  #24
Jankot's Avatar
I am using ELM 327 with Torque pro on samsung galaxy a4 lite with my D2 2004 ... there is no problems what so ever.
its a great app to keep tracking your temps and clear faults now and then .
filbs
Feb 24, 2022 07:54 PM
austinlandroverbill
Jul 4, 2019 04:16 AM
99DiscoFlyer
Dec 3, 2015 02:58 PM
todd0765
Dec 6, 2012 06:30 PM
thehun
May 4, 2012 04:24 AM
