Torque Converter Bolt direction
Old Mar 30, 2008 | 06:34 PM
kraelo's Avatar
Default Torque Converter Bolt direction
the 4 bolts that hold the torque converter to the flex plate, if you're looking at the bolt from the back, does it loosen, if you turn it to the left, or to the right ?
Just wondering if it has reverse threads or not, it does not want to budge either direction....
Old Mar 31, 2008 | 01:57 PM
kraelo's Avatar
Default RE: Torque Converter Bolt direction
Got the torque converter off (normal rotation) and flex plate and balancer, and need to know how to get the hex head bolts off ... that's holding the crank in ...
I've used a impact gun, doesn't turn it hard enough ...
any other suggestions ?
Old Mar 31, 2008 | 06:58 PM
Landzu's Avatar
1/2" inch breaker bar,, a impact is only as good as the volume of air you have.
Old Mar 31, 2008 | 07:08 PM
kraelo's Avatar
How do I stop the crank from turning, my wife is only so strong holding the front, and I can't break the bolt loose and hold it at the same time, haha
Old Apr 1, 2008 | 12:02 AM
geotrash's Avatar
Use a strap wrench on the crank pulley.
focusontheworld
Oct 21, 2012 01:00 AM
Engnur
Aug 30, 2009 05:12 PM
LRScott
Mar 6, 2009 11:42 PM
sailorcolin
Apr 17, 2008 08:21 PM
jared
Dec 20, 2007 06:51 AM
