-   Discovery II (https://landroverforums.com/forum/discovery-ii-18/)
-   -   Torque spec needed-RAVE not listing (https://landroverforums.com/forum/discovery-ii-18/torque-spec-needed-rave-not-listing-44258/)
boris_gti Oct 6, 2011 08:22 PM
1 Attachment(s)
Does anyone have a correct torque spec on the oil pump cover? Phillips bolts on the inside of the timing chain cover. See picture bellow.
Or do I just go a good old "hand tight"?
Thanks!
Savannah Buzz Oct 6, 2011 08:46 PM
In the overhaul manual section, found this for 4.0 and 4.6 engines; under torque wrench settings:
Oil pump cover plate screws ** . . . . . . . . . . . . . . . . . 4 Nm 3 lbf.ft
Oil pump cover plate bolt ** . . . . . . . . . . . . . . . . . . . . 8 Nm 6 lbf.ft
Spark plugs . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 20 Nm 15 lbf.ft
** Coat threads with sealant, Part number STC
50552 prior to assembly.
Note: they list every other torque it down setting for places you didn't even know they had bolts...
boris_gti Oct 6, 2011 09:48 PM
Thanks Buzz,
I needs to get to know the RAVE a little better I guess.
It looks like "Part number STC 50552" is Loctite (blue).
Thanks again!
Savannah Buzz Oct 6, 2011 11:10 PM
The RAVE, (Rovers A'int Very Economical) is like an onion, many layers. I think the workshop manual is geared toward quick fix parts changers, and the overhaul toward the master guys (and gals!) that would be entrusted with something more complex than swapping an alternator. Most dealers want lots of the quick fix, and so do the techs.
