towing limits on a discovery
Old Aug 2, 2005 | 05:34 PM
RobFrey1's Avatar
4wd High
Default towing limits on a discovery
I own a '97 Disco and wondering if it's possible to pull a sailboat of 7000lbs and a trailer weight of 1,000lbs. I understand the disco's do have transmission coolers but still wondering if it's just too much weight. I wouldn't need to travel very fast either.
Regards,
Rob Frey
'97 Discovery
Old Aug 4, 2005 | 12:36 AM
duboff's Avatar
Default RE: towing limits on a discovery
i have a 96 disco. 4.0 automatic. per the manual 7700lbs. It is over the manufactures limit, but a close call.
hope it helps. gotta love a rover. duboff
Old Oct 13, 2005 | 08:51 PM
wildhorses's Avatar
What do you guys think is the max towing of a disco 1 is on hills here in utah. I have a f350 powerstoke that I tow my 3 horse with now. It should weigh only around 5k with two horses in it. I know the manual says around 7k, but I assume that is on flat ground at see level? What do we really see? Is there a tranny cooler on these? I do see it has a class two hitch on it.
Old Oct 14, 2005 | 12:14 PM
anonimaus's Avatar
Rob-You are a bit high on the weight, and will want to keep an eye on the transmission and T fluid.
Wildhorses-I believe it is for flat ground. Same warning on transmission wear due to the hills. There is a transmission cooler. Look just above bumper and you should see a cylindrical cooler mounted in front of and along the bottom of the radiator.
OffroadFrance
Off Topic
Apr 8, 2015 04:12 PM
STi NUt
May 30, 2014 03:16 AM
tbesselman
Feb 13, 2012 07:01 AM
STi NUt
Engine & Internal
Sep 8, 2007 01:22 AM
DNTL911
Nov 29, 2005 11:19 PM
