Traction Control, ABS and Hill Descent lights on
Just recently after starting up, the three lights (Traction Control, ABS and Hill Descent Control) remain lit (amber). As far as I remember, there are no associated warning chimes. It seems to happen when I've been parked facing uphill. Restarting on level ground clears the lights.
Any suggestions ?
TIA
Any suggestions ?
TIA
It depends on what fault caused the warning lamps to be illuminated. Some faults get stored for at least several drive cycles even if the fault is no longer present. You will need a code reader that reads ABS codes. Many read engine management codes only. Also, it's odd you get the Three Amigos without the warning chime sounding three times.
