traction control issue, solving 3 amigos
im going through the process of fixing the 3 amigo's, i had did the shuttle valve bypass i found on the forum which worked great and got rid of my code for that but i have the code 4012 (pump faulure 1 high level at x2 pin 8 without pump acuation) which i couldnt find anywhere (on hawkeye btw). theres a million threads on this but i cant find my exact issue. i was able to clear the codes and i have zero codes that pop up but, i have only the abs light. this is causing the traction control to kick on at all times, when i drive 2 mph it kicks on. any sudgestions? i have a video of this happening if it would help
Originally Posted by escott16
(Post 629408)
The quickest way to eliminate is using a Nanocom, Haweye, Linx etc in conjunction with RAVE either the owners manual or workshop manual (download RAVE from this forum) The fault I have found is often either a defective wheel sensor, sensor plug or socket or broken sensor wire. |
Anyone else have an idea?
(Post 629408)
Originally Posted by Bal D Correa
(Post 769851)
Hello, I am having the exact same issue happening to me. I know it's been a while that you posted this, but by any chance did you figure what was the problem?
