Transmission froze!?! Literally
So have not driven the Disco for a couple days. I'm usually pretty good about starting it everyday specially when it's cold out. Left it two days without starting. Today got in it and needed to jump it, new battery not even a year ago. Anyways it was definitely strained while turning over. Finally fired and M and S lights flashing and would only go in drive. Sounded like ice was on my transmission. Pulled in garage let it warm up for couple hours. Went back started it up and all back to Normal. Weird.
Probably moisture in the xyz switch froze up. Once warm, it corrected itself. Sounds to me like the xyz switch is on the way out and the cold uncovered it. Good luck!
I had the exact same thing happen to me today.... Hadn't driven it in about a week and it was slow turning over. 20 something degrees outside.
I attributed it to a low battery voltage, which I think can be one of the causes of Limp Mode... I don't think it was the xyz switch as I just changed it last month with a known good one... |
Very true. Low voltage could cause the limp mode. He also said it would only go into Drive. That could be the xyz acting up as well.
Originally Posted by dtmbinb
(Post 632092)
It was -9 out last night here in Cincinnati
Originally Posted by sickws6
(Post 632099)
I have decided I'm not heading north again in the winter unless its at gun point.
It's blistering.
(Post 632099)
