Transmission oil issue
Old 10-06-2012 | 11:03 AM
ratijs100's Avatar
Default Transmission oil issue
Hello everybody,
I am replacing transmission fluid on Disco 2 and I am buying Dexton IID as its written in Rave manual. There are two options: one is red fluid and another is yellow one. Does anybody know if the colour matters? and what are the differences between those two?
Old 10-06-2012 | 12:16 PM
There are better fluid now being made since your manual came out.
Consider using Vavoline's high mileage Dextron for vehicles over 75,000 mile and put a bottle of Lucas tranny additive for a better/happier tranny.
Old 10-06-2012 | 12:22 PM
IID is the WRONG trans fluid!!!
Dexron III is what it takes NOT Dexron IID.
Old 10-06-2012 | 12:37 PM
lr2001silver's Avatar
Banned
Do not use the IID use dexron III with some additives will last for ever this way!
Old 10-07-2012 | 01:03 PM
ratijs100's Avatar
thank you for replies. i bought Valvoline MaxLife.
I replaced filter and gasket, then cleaned the oil pan and refilled, but i could pour only 5 Litres. After driving about 40 minutes, I went back and added around 300-400 grams and it was full. I still have left some oil, so will drive for a week and next weekend will check the level and will add some oil if it will need.
Old 10-07-2012 | 01:38 PM
Always do the second fill/top off with the engine running with your tranny in park while on perfectly level ground.
Old 10-08-2012 | 02:41 PM
binvanna's Avatar
do you measure with leaking tranny cooler lines or without?
Old 10-08-2012 | 07:21 PM
jfall's Avatar
Don't understand.
If the transmission coolant lines are leaking - you don't pass GO.
You need to replace those first...
Old 10-08-2012 | 08:42 PM
Banned
What does that mean?
Old 11-26-2012 | 03:24 PM
Seneca's Avatar
where is the best place to purchase transmission coolant lines?
Quick Reply: Transmission oil issue
