Transmission problems
Transmission will not go into reverse....Little red lights along gear selector do not illuminate in park,reverse,1st and 3rd... Drained fluid looks really dirty brown got about 4 quarts on the drain job... Checked voltage at the alternator got about 13.8 volts....Key wont come out of ignition until I unplug battery..Any help please..
If you only got 4 quarts out I would run it and flush it again and look into changing the filter at a minimum.
You need to take a lot better care of your ride. That tranny is probably fried but I would try another drain and refill.
Do you even know how to fill the tranny, two times, second time with the engine running and the tranny in park. Voltage is also pretty low, may be causing some issues. |
Mike is right, its very clear that if you don't take care of things they fall apart. At the top of the forum he has a maintenance section and you don't have to wait until you hit that mileage to perform his list it should be done as soon you purchase a new rover.
Originally Posted by Disco Mike
(Post 337009)
Do you even know how to fill the tranny, two times, second time with the engine running and the tranny in park. Voltage is also pretty low, may be causing some issues. 60=Purge vent valve/Power stage fault 73=Mass airflow sensor fault 1F=Rough Road signal implausible AA=Air conditioning compressor power stage fault 3505=Rear right outlet valve open circuit 1006=Front left sensor signal erratic 1364=Shuttle switch electrical failure I have not had any warning from my transmission other than just the other day...I think..I went to reverse and nothing happened m and s lights flashed and lights were flashing at the shift lever as well..so I stopped and parked ...shut the truck off and started it up again..It went into reverse ok so I moved on..I guess I need to do some reading in the shop manual..Funny thing about this is from park to drive sometimes you can't move the lever without pumping the brakes several times..then she goes into Reverse..the lights for reverse come on by the way and of course no movement.. Man I hope I did not get someones lemon..I like the truck..but it is my only ride so..ya know fixes must move quickly.. |
Just because you got it from a doctor, astronaut, or the pope himself does not mean it was serviced correctly. Unless you have a service records from every single time it was in the shop you have to assume it has had nothing done at all. As far as the mechanic talking to your wife i guess you need to talk to the mechanic yourself and get the details so you can stay on top of your only vehicle. If your CEL is illuminated there is a problem that needs fixed not wait a few months and see what happens.
Too bad you did not have a pre-purchase inspection done prior to buying, would have caught all this up front and dealt with it at the purchase.
As for only driving in the sand, that is the hardsest surface for a tranny. For the future, read my majpr service list at the top of the D2 section and do it all to try and salvage your truck. As for those codes, if you can, go buy a local auto parts store where they will read the fault codes for free, get the fault code numbers and give us a list, the codes you provided or not Rover codes as such and won't help you fix any of the problems. By the way, how mechanical are you? |
Looks like you will need to check the charging system and maybe replace the battery.
The tranny needs to be flushed and topped off when the car is running to insure you get the proper amount of fluid back in. and also a shutter valve repair. Search option a or b and you find a ton of info. |
(Post 337052)
As for only driving in the sand, that is the hardsest surface for a tranny. For the future, read my majpr service list at the top of the D2 section and do it all to try and salvage your truck. As for those codes, if you can, go buy a local auto parts store where they will read the fault codes for free, get the fault code numbers and give us a list, the codes you provided or not Rover codes as such and won't help you fix any of the problems. By the way, how mechanical are you? Here's the results P0447-Evap Emission vent control circuit open P0102-Mass Air Flow Circuit Input low P1884-No definition code..any idea what this one is? P0134-Oxygen sensor Bank 1 sensor 1 I am average mechanically can do brakes, alternators, starters and most cosmetic stuff just learning multi-meter use ...this is where the real skills come...,in my opinion; trouble shooting correctly and timely..and not just throwing parts at an area and see if it works which I have done in the past..I am gonna replace passenger side exhaust manifold..which has a decent crack in it now.. got the parts but trying to figure this transmission issue out first..Could it be as simple as a filter change? What does the strong rotten eggs smell come from? MAF??? just noticed it in the past few days..I could smell exhaust fumes up front cause of the manifold leak but I really smell sulphur and the truck is hesitating some at idle... I read in rave last night about a Stall Test..I did that this morning and registered about 2200 rpm engine seemed a little sluggish..what do you think? Thanks for all your advice DM.. |
Originally Posted by ebg18t
(Post 337054)
