Tried the Rave
I tried downloading the Rave manual only to have my Mac screwed up by it changing homepages etc.. I reverted back, sorta. Where can I get a manual that doesn't screw my computer up?
I need the manual so I can find a good spot to plug my 3/8" NPT water temp gauge in. I've searched and searched, but I only found one link in a guy's sig. That's the link that did nothing but harm. landroverresource.com or something like that. |
To add a temp sensor, a simple solution is to put it in an adapter clamped into the upper coolant hose(hot coolant from engine). Turn sensor to be in the coolant flow. Attach wire lead , run wire to new gauge in cabin.
If it's the workshop manual, here: http://www.landroverresource.com/doc...hop_Manual.pdf
I'm not really sure it will give you the info you need. |
