Tried the Rave
Old Sep 11, 2015 | 12:20 PM
Twix's Avatar
Default Tried the Rave
I tried downloading the Rave manual only to have my Mac screwed up by it changing homepages etc.. I reverted back, sorta. Where can I get a manual that doesn't screw my computer up?
I need the manual so I can find a good spot to plug my 3/8" NPT water temp gauge in.
I've searched and searched, but I only found one link in a guy's sig. That's the link that did nothing but harm. landroverresource.com or something like that.
Old Sep 11, 2015 | 01:18 PM
PalmettoDisco's Avatar
To add a temp sensor, a simple solution is to put it in an adapter clamped into the upper coolant hose(hot coolant from engine). Turn sensor to be in the coolant flow. Attach wire lead , run wire to new gauge in cabin.
Old Sep 11, 2015 | 02:12 PM
antichrist's Avatar
If it's the workshop manual, here: http://www.landroverresource.com/doc...hop_Manual.pdf
I'm not really sure it will give you the info you need.
javoli002
Mar 29, 2009 10:56 PM
salve7
Oct 31, 2008 11:39 PM
DDLR3
Mar 3, 2008 01:31 PM
badfysh
Aug 7, 2007 09:42 PM
razorbak
Aug 6, 2005 04:11 AM
