Trying to remove rear diff pinion flange
Does anyone know how to remove the rear diff pinion flange without the LR tool specified in the RAVE? I am trying to change the seal but can't get the centering pin out of the flange to get to the nut.
Watch video around 8.10 onwards. Ashcroft Transmissions
The outer bearing race of the cardan (Hookes) didn't though!!!
I tried the screw through the socket technique but stripped the threads in the pin.
http://www.scribd.com/doc/47742463/3...Flange-Removal
It seems everyone around the world has a problem with these centering pins/spigots. It would appear they are held in with Loctite so you need to break that seal using something like acetone or cellulose thinners to dissolve the Loctite overnight. Then heat up the flange and pull with a slide hammer or make up a tube puller but you may need to tap out to something around M12 to get a real 'purchase' for an extractor bolt. Short of this there is the LR 'special' tool which you can hire or take an angle grinder to the flange and split it as a last resort being careful not to damage the pinion shaft. Good luck and post how you get on - I've got to do mine sometime and I'll need a 'guinea pig' to lead the way and who has endured the fight with this PITA.
Loctite - the Maintenance Expert
You may get some ideas from these threads
Help with rotoflex/drive shaft upgrade - DiscoWeb Message Boards
removing rear pinion flange - Australian Land Rover Owners
Land Rover Owner • View topic - Rear Diff Flange Puller - LRT-51-008
Rear diff pinion seal on 300TDI Discoveries - Land Rover Technical Archive - LR4x4 - The Land Rover Forum
An LR main dealership should be able to supply one. Try Atlantic British or Rovers North as they may well stock them as the problem cannot be unique - I hope.
Look at page 51-7 of the RAVE Workshop Manual and they show an LR special tool for removing the centering pin/spigot. It should be fairly easy to fabricate something similar using say a 3"-4" diameter x 3" long pipe with a heavy steel plate say 3/8" tack welded to one end with a hole in the center and put a high strength 8.8 bolt through the hole screwed into the spigot and use it as a tube puller. Put plenty of lube on the threads though. also washers under the bolt head with lots of moly grease to avoid seizing. Good luck.
PITA
Soak the pin in acetone/cellulose thinners overnight to release any Loctite engineering adhesive they've used it breaks down the polymers.
What diameter is the pin size that sticks out of the flange where the central thread is located?
