TWO ISSUES suspension and oil leak
My land rover was leaking oil some. I found out this was very common in these rovers.
The air suspension issue was fixed by switching to coils. I didn't notice much of a difference. It was pretty easy.
Gabriel O.
Gabriel O.
RE: TWO ISSUES suspension and oil leak
If possible, you should get your vehicle to a shop that can read any air suspension fault codes that are stored in the computer. It could be a number of things, like a ride height sensor, air spring, compressor, etc. ----but hard to diagnose without the codes.
The oil leak from the oil pan requires removing the pan, and replacing the gasket which costs about $25.00 (for the part). Fluid leaks are, to a certain degree, a part of owning a Land Rover. Some are more serious than others and require immediate attention (like coolant leaks). Read my primer under the tech info sections at www.eurotekapg.com ---as this will give you a better idea on what to look for.
regards,
Geoman
eurotek apg
Northern California
regards,
Geoman
eurotek apg
Northern California
mvjimenez123
03-14-2012 02:32 PM
nijones25
04-27-2011 11:38 PM
