Tyre Pressure
Old Jul 31, 2008 | 03:57 PM
gsgtsg's Avatar
Default Tyre Pressure
Hi,
I have just had a set of four new tyres on my Discovery 2 year 2000. These are the General Grabber AT2 (255/55 R18) tyres.
Please advise what the tyre pressure should be for the front and back when used on road/moterway?
Thanks.
Old Jul 31, 2008 | 04:10 PM
Disco2Guy's Avatar
Default RE: Tyre Pressure
There should be a sticker on the inside of the driver's door with the info you are looking for, and check the torque of the lugs too (should be 103 ft/lbs).
Old Jul 31, 2008 | 07:43 PM
No more than 103ftlbs. 35psi front and 40psi rear.
Old Aug 1, 2008 | 10:05 AM
Switzer's Avatar
Be careful not to fill the tire beyond its max cold rating. Land Rover recommends an unusually high rear pressure, more than the Grabber AT2 tires can handle, if I remember correctly.
I run 38psi front and 40psi rear. Great tires!
Cheers,
Pete
Old Aug 1, 2008 | 11:31 AM
5#'s over what the door sticker shows you will give you better wear.
megathunder
May 5, 2014 09:18 AM
Spyderman
Tires
Nov 28, 2006 05:51 AM
kpxus
May 13, 2006 08:13 PM
englishboyonice
Mar 29, 2005 07:31 PM
englishboyonice
Feb 23, 2005 04:04 AM
