u-joint replacement/D2
Old Jan 24, 2008 | 12:15 PM
FJL's Avatar
FJL
Default u-joint replacement/D2
Mike has been warning everyone to replace the double u-joints on your Disco II. Just did mine and in the nick of time. Bearings where rusted and the u-joints where about to fail. There was no vibration or warning of certain impending failure. If you haven't changed yours.......do it now.
Old Jan 24, 2008 | 12:28 PM
Default RE: u-joint replacement/D2
"DITTO"
Old Jan 24, 2008 | 01:03 PM
DV57's Avatar
Just curious...how many miles do you have when you replaced your u-joints?
I've thought about replacing it, but Mike said to wait...since my Disco is still under warranty.
2003 Disco SE w/28,500 miles
Old Jan 24, 2008 | 01:14 PM
FJL's Avatar
FJL
I had 92,000. When your warrentee is up I'd change to new ones with grease fittings.
Old Jan 24, 2008 | 01:44 PM
Darover's Avatar
Just had mine done yesterday with spicer u-joints which are apparently the best and most recommended onesaccording tothe driveline experts I went to. He said that neapco are absolute crap ( which confirmedwhy they are known ascheapco on most forums) whichI could have had installedfor almost half the price. Then you have precision which are half way between the 2.
My 2000Disco has 56000 miles, and they said that they didn't have to be changed. But they saw that by disassembling them. So although they were fine, I'm still glad to have had them done and to now have greasable ones. At least now I know.
ONE LESS THING TO WORRY ABOUT !!!
New u-joints, new head gaskets, new front gasket, new O2s, new rad, new y-pipe gaskets ( no more ticking at all)new synthetic fluids everywhere, tranny filter changed....BY god, I think I'm done. WHOOHOO! look at me
Old Jan 24, 2008 | 01:46 PM
jdelp's Avatar
Replaced under warranty due to severe vibration at 55k. It literallyhappened as I was driving on the highway home from work one day, drove it straight to the dealer and parked it. I knew right away what it was. Luckily total failure never happened.
Old Jan 24, 2008 | 02:33 PM
DV57's Avatar
Darover,
where did you buy your spicers?
Old Jan 24, 2008 | 06:03 PM
Darover's Avatar
The driveline shop ordered them, so not sure where they came from. I had the choice of all 3, but went with their recommendations. Its most likely a supplier that has access to all of them...why???
Old Jan 24, 2008 | 06:47 PM
Elhoff's Avatar
Did mine back in Nov. Got the U-joints from Rover Connection and had them installed at a local drive line shop. They looked at me a little funny when I first requested the work since there was nothing obviously wrong with eht originals, but as soon as I explained, they were right on it.
I got very lucky with my original set given that I'm at 125,000 miles!
Old Jan 24, 2008 | 07:28 PM
okdiscoguy's Avatar
ORIGINAL: Darover
Rumor has it they quit making it, and I can't find them for purchase online anywhere..... Spicer 5-4X, right?
