Ujoints
RE: Ujoints
Yes it is that simple, almost. You will also have to put the new clips in that hold the u-joint caps on. Yoursupposed to use a special tool but everybody in the world just uses needle nose pliers.
As for grease, any good automotive grease will be fine. I use "Green Stuff", you can buy it at AutoZone or Tractor Supply Company.
Make sure that you grease them after you install them and then grease them at every oil change.
