Unresponsive window, switch or motor?
Old 03-07-2017, 02:37 PM
KingKoopa's Avatar
Default Unresponsive window, switch or motor?
Passenger side window has been finicky for awhile and is now unresponsive.
In the past I was able to rapidly hit the switch a number of times and it would eventually react and work fine for the rest of the day without issue. Now I can't get anything from it.
The motor never made any complaining sounds so im leaning towards the switch but If it's "always" the motor then ill start there.
Old 03-07-2017, 02:50 PM
shanechevelle's Avatar
Easiest thing is to get a multimeter and test the switch, then, if that checks out, test the motor at the door.
Old 03-07-2017, 03:25 PM
LR03NJ's Avatar
Hmmm! What else to check. This is happening to me right now and multi meter not reading anything. Only one window.
Old 03-07-2017, 03:26 PM
Luckyjayb's Avatar
Fuses?
Old 03-07-2017, 03:30 PM
LR03NJ's Avatar
Are all those windows have separate fuses? Mine was working when the door was closed and when its open, the wondow wont work, now its completely dead. Seems like same as King's problem.
Old 03-07-2017, 03:36 PM
jamestfl's Avatar
can't you switch switches and check. That's easy on mine as the switch housing plate thingy is 'easily accessible'.
LR03NJ (03-07-2017)
Old 03-07-2017, 03:42 PM
LR03NJ's Avatar
Its very nice theres always smarter people here in the forum. You're right Jamestf, I just got so annoyed dismantling the entire door panel and gave up. I only checked one switch. Thanks
Old 03-07-2017, 03:45 PM
Luckyjayb's Avatar
Old 03-07-2017, 03:47 PM
Luckyjayb's Avatar
Hope that helps
Old 03-07-2017, 03:50 PM
Luckyjayb's Avatar
Cj7jed@gmail.com
04-14-2016 10:24 PM
Bob Loblaw
06-05-2013 09:46 PM
Travelor
07-11-2011 06:41 PM
rockcity
01-05-2011 11:13 AM
Quick Reply: Unresponsive window, switch or motor?
