Upper transmission cooler pipe or line
I am trying to install a new upper transmission cooler line. I removed the old one easily owing to the fact it could bend it out. I am losing faith that I can install the new one without dropping the tranny. I am looking for advice as I do not want to drop the transmission. thanks, Kevin
"It's easier to access if you drop the back of the transmission/transfer case, or remove the motor mounts to lower the engine."
Now that I am no longer under the Rover, relaxed and devoid of red fluid all over me, I googled my question and found this answer on a number of different forums.
__________________
__________________
There is nothing easy about either of those "solutions"
But yes, whoever put that oil line up top like that needs to be taken out and shot, in fact, whoever designed half the **** on the V8 driveline is an idiot.
__________________
__________________
Thanks. It was a major PITA trying to order it on the phone (the upper line on the transmission which connects to the lower line on the cooler.....). It is the one which requires contortionist capabilities to remove (and is the upper line on the transmission.) Cheers,
I did that job. Biggest pain ever. Worst job on the disco ever. Did it without dropping trans on the garage floor. The only real pain is getting the compression fitting in. You just need to remove the trans switch and get it out of the way, and have tons of patience. Small hands (which I don't have) helps. I think I was finally able to get it in using a small piece of wood to apply pressure as I tightened.
Hello all. I had to lower the transmission with a 3 ton floor jack and a block of wood, and on the passenger side I had to remove the transmission mount completely. The switch on the driver's side like |Sanfu stated, has to be removed, in my case, to tighten the pipe up. I went to the engine bay and the rotten jerk leaks....I simply do not know what to do, other than (1) cut the hose and use a 1/2 hose with clamps which failed last time, or (2) get another cooler that has decent fittings. Any thoughts (as the plastic clip clicks, but the fluid comes out from under it.....
Bringing this full circle. This repair was a major PITA. I ordered and installed a new (used) cooler and I am up and powering the oil industry again. The darn cooler outlet pipe became non circular due to previous jury rigging and the use of hose clamps so it would never seal properly nor sufficiently. DiscoMike - great speaking with you and thank you for your help. Sanfu, thank you too, for your emails and assistance.
