Upper Vacuum Leaks - Points of Failure
Upper Vacuum Leaks - Common Points of Failure
Chasing some P0174 and P0171 codes and looking for possible vacuum leaks. My plan is to build one of the DIY smoke testers and pressurize the system to see if I can find anything.
In the mean time I'd like to ask the collective hear what and where are some of the more common points of failure that cause upper air leaks. A few that come to mind would be brake booster line, air injection lines, fuel injector o-rings and manifold gasket. Can you name any others.?
MrHSE7 (12-13-2019)
Pretty much any plastic or rubber hose back of the MAF will be suspect, including the joint between the MAF and the intake, which is supposed to have an O ring but often doesn't. There's also the PCV hoses, the IACV hose, and the throttle body gasket.
If you're getting a lean code on both banks, it's not going to be a fuel injector. That would be too far downstream.
Just following up with where I am with all of these codes.
After extensive searching for a upper air leak to no avail I came back to the forums and was doing more research. I read a post where someone said to disconnect my mass air flow sensor and see what happens. As soon as I removed the MAF connector the car immediately ran better and was no longer stumbling at idle. I cleared the codes and drove it for sometime and all seems well. No more P0174 and P0171 codes. After a restart I did get MAF related codes from it being unplugged. Im guessing that my 2 year old (BOSCH) MAF is failing. Ive already tried to clean it with no results. Ill have to buy a new one I guess or try and see how to test the current one.
In the mean time will I be OK to drive the car with the MAF disconnected? Will I do permanent damage? Seems to be running better than it has in a long time.
