Using a "Signature" Pic
Old Jul 29, 2009 | 10:54 PM
llPANCHOll's Avatar
Default Using a "Signature" Pic
So I finally got around to putting up a Sig Pic, and figured I would take some of the guesswork out of it for any body else that is interested in doing so but hasnt got around to it.
First you will click on User Cp in the Bar above..
Then "Edit Signature"
Then at the bottom of the page you should be able to pick you image from your computer and upload it.
Be advised that:
The maximum size of your custom image is 500 by 100 pixels or 9.8 KB (whichever is smaller).
So you might need to adjust the image you plan on using.
Once you upload the image you should should see it there in the "Edit" page, this does not mean you are done. You need to click the "Insert Sig Picture" text and that will place some [SigPic] text in the text field.
Then simply Grab the image with your cursor while holding left click and drag the image up to the text box.. Position your Curser so that the flashing "|" is beteween the bracketed [SIGPIC]|[SIGPIC] text and then drop it, it should insert a string of text in place of the picture..
Save it and you are done!!
If you want to center the Picture just Highlight all of the text and then click on the Centered text below the "Fonts" bar
Old Jul 30, 2009 | 12:43 AM
Torancis_LR's Avatar
Very cool PANCHO.Thanks for the tech tips.
I'll test mine here. Can't wait to get a pano of the Disco!
Old Jul 30, 2009 | 08:12 AM
Glad you posted that information, hope others use it, I will soon.
Old Aug 15, 2009 | 06:54 PM
98roverguy's Avatar
This isn't working for me. I can upload the image but the "Insert Signature Picture" link/text does not appear. Can someone please advise?
Thanks.
Old Aug 15, 2009 | 07:02 PM
llPANCHOll's Avatar
You dont have the brown text in your control panel or the pic doesnt show up in the preview??
Old Aug 15, 2009 | 07:09 PM
98roverguy's Avatar
Pancho,
I can upload the pic. However the "Insert Signature Picture" text (above the "Delete current image" text) that you have circled in red does not appear. There's nothing to click on to get the [SigPic].
I'm stuck on this step:
"Once you upload the image you should should see it there in the "Edit" page, this does not mean you are done. You need to click the "Insert Sig Picture" text and that will place some [SigPic] text in the text field."
Old Aug 15, 2009 | 07:12 PM
llPANCHOll's Avatar
Make sure the image fits into the size requirements shown in red
Old Aug 15, 2009 | 07:14 PM
98roverguy's Avatar
Yeah, I saved yours then uploaded it to test it and still I get nothing. Does it still work for you?
Old Aug 15, 2009 | 07:18 PM
llPANCHOll's Avatar
Ill try to help more when I get home..
Email me the picture you want to use and I can probabky circumvent whatever issue you are having by hosting it offsight and just giving you a line of text to post in your sig text box
Old Aug 15, 2009 | 09:26 PM
llPANCHOll's Avatar
Ok I cant host it offsight, but I got your picture to work as my sig, carefully follow the steps again,
1. Choose the file to upload
2. Press the upload button below that field
3. Grab the picture and drag it to the text box
4. Place [SIGPIC]image text here[/SIGPIC] around the image text
