Valve cover gaskets?
Old 09-22-2010, 12:45 AM
bflener's Avatar
5th Gear
Default Valve cover gaskets?
I am going to have to put new valve cover gaskets on my 04 Disco I just bought. Where can I get the best gasket (doesn't have to be the cheapest), and what other gaskets, and things should I do while I'm at it? I'm also going to do new plugs and wires (what have you guys had the best luck with?) Any help would be great!
Old 09-22-2010, 01:47 AM
mwindth's Avatar
WHY? Just tighten the bolts...are you talking about head gaskets? Are you loosing coolant? If so check here: http://www.roverparts.com/Parts/STC4082HBK.cfm
Also, have you re-built the front u-joints with grease-able ones? That should be your first priority...period.
Magnacor 8mm wires (best price here: http://www.apexperformance.net/CartGenie/prod-1155.htm ) and Bosch Platinum Plus 4s are what I use...make sure you get 8mm due to high temp of our aluminum engines.
Spike can chime in on exact socket size for your valve cover.
Congrats on your disco...you will enjoy!
Old 09-22-2010, 07:05 AM
lipadj46's Avatar
valve cover requires an 8mm 12 point socket as I recall. It never hurts to change a gasket that is leaking as a bonus you get to see if your engine is a sludgy mess or heavily varnished (and take pics and post them up here so we can see the filthy mess!). I always just get rover gaskets from the dealer unless their prices are too crazy.
Old 09-22-2010, 07:48 AM
tee51397's Avatar
Correct, 8mm 12pt - deep. ditto on all the above.
Old 09-22-2010, 04:04 PM
'BamaBoy's Avatar
Just changed the valve-cover gaskets on mine. Here's the "filthy mess" in my engine!
Old 09-22-2010, 04:32 PM
lipadj46's Avatar
Don't be smug with that clean POS
Old 09-23-2010, 08:44 AM
So, why didn't you get rid of those crappy factory plug wires while you were at it??
Old 09-23-2010, 04:38 PM
timdunbar's Avatar
Amen Mike.
Old 09-24-2010, 01:07 PM
'BamaBoy's Avatar
What factory plug wires?
I changed those out the same night, figured I was already in there, and that SAI is a bear to get around. Easy as can be when I can actually reach them coils in the back.
Old 09-25-2010, 09:21 AM
I was basing my question on the picture you submitted showing the old grey wires.
Quick Reply: Valve cover gaskets?
