Valve covers looked WASTED.
I have my 02 apart for a "head job" and my valve covers just looked like crap. The original silver gray paint was almost all gone and covered in corrosion and the inside had thick oil buildup almost like tar or resin, Baffles me though nothing else has any corrosion but the valve covers. So I decided to coat them in a metallic silver I normally would of done them in something obnoxious like lambo green or candy blue but for the land rover I didn't want it to be all blinged up.
I replaced the old crappy self tapping screws that hold the wire looms in place with new stainless steel machine screws. I tapped out the existing holes with a 10-24 tap.
Here are a few before pics while I was in the process of degreasing them
The Inside, I actually had alot of the grime scraped off before i took this pic
tappin holes
and the finished product. I'm real happy with the results.
I removed the inside plate and low pressure media blasted and went over with a stainless steel wire brush to smooth the surface.
Thanks for looking Mike.
tappin holes
on
So, what is a lot more important is all the burned crap on the inside of your engine, what are you doing about that? What brand and weight oil have you been using and how often have been changing the oil.
I would highly recommend a good engine flushing to get rid of some of that for your engine sake.
