Valve stem seal replacement questions
Old 08-12-2020, 09:59 PM
DiscoID's Avatar
Default Trick to getting the old valve seals off?
I'm in the middle of this job right now, and wanted to know if there's a trick to getting the old valve stem oil seals off, and installing the new ones? They seem to be pressed on, and there doesn't seem to be an easy way to simply "grab" them to pull the old ones off, nor an easy way to "press" the new ones on without potential damage.
Can someone let me know if there's a trick that I can find searching the forums? Thanks for any advice.
Old 08-13-2020, 02:45 AM
frostythor's Avatar
Hi they have just gone hard with age, check out the new ones you can probably slightly squeeze the between your finger, because they are new, and not old a hard, which is why the a leaking
they are just push on , so pull off with a set of grips/pliers
DiscoID (08-14-2020)
Old 08-13-2020, 09:39 AM
Las4444's Avatar
6th Gear
Twist them off carefully with a pliers. I used a socket to tap in the new ones.
cmb6s
05-07-2019 09:25 PM
MrHSE7
09-14-2016 07:18 AM
fpdavis3
03-08-2013 08:27 PM
sruff
06-20-2011 06:22 AM
tailchaser0527
04-18-2009 09:38 AM
Quick Reply: Valve stem seal replacement questions
