Varying waterfall with varying RPM
Heads recently redone by PO; no overheating indicated by stock gauge, new ultra gauge has not arrived yet. Had coolant flushed before purchase, been bleeding a couple of mornings... Driving today I noticed that I can vary the waterfall sound (in park) with the throttle. First thing I thought was head gaskets, but I have no trouble codes, white smoke or overheating.
Could it be a crappy hose clamp drawing in air when I rev?
Seems to me, if a head gasket was that bad that I could immediately hear a change in waterfall sound then I would be having other symptoms.
Go thru each hose and inspect for cracks and inspect the clamps.
Pay attention to the small hoses -
one at the radiator, a few on the coolant bottle.
There are two smaller hoses at the air intake for a heater there.
And, there are metal hoses into the block - with O rings which can leak..
Any one of these can cause problems.
Of course, you may not have bleed the system correctly.
I don't bleed my system with that bleed screw.
I copy how the Discovery I works.
You can unclip the coolant tank.
It is make to unclip.
Raise it high.
Put rags under it.
Open the cap - slowly if hot.
Put in coolant to the fill line.
Run the engine a 1,500 RPM for about 8 minutes.
Then fill to the fill line again.
Put on the cap .
Tuck the bottle back where it was.
Done.
Should have no more water fall sound.
I did this is Boulder Colorado ONCE in March 2012.
Never had to bleed it again.
And, I have gone about 3000 miles now from that bleed.
Raise it high.
Put rags under it.
Put on the cap .
Done.
