Voltage loss... Hmmmmmmm
Decided to do some more research before dropping cash on a new alternator.
Testing at the back of the alternator gave me 14v. Testing at battery reads 13.7
With lights and both AC running on high ug reads 13.5. Battery was 13.6 alternator 13.9
Further testing with 1 lead on alternator positive terminal and other on battery positive showed .3 volts.
This is leading me to believe the alternator is fine and I'm loosing voltage in the cable
Does my reasoning seem correct?
Yeah.. cables corrode inside and that'll do it.
I replaced my negative cable with a 2 gauge wire from Autozone and a set of marine clamps, getting better voltage every since that, and no more M+S lights on startup. I ran one wire to the block next to the battery, and another to the alternator bracket. IMO a better setup than factory, less resistance being it is two cables instead of one to multiple locations.
I'm planning to do the positive cable next.
DiscoIIBrandon
03-14-2012 07:26 PM
