Want to make OME heavy duty suspension more so
Would adding 1 inch spacers front and rear to OME heavy duty springs with 2 inch lift offer any additional benefits in terms of the amount of weight the vehicle can support? I'm putting an ARB bull bar/winch bumper and an 8,000 lb winch on my 2003 Discovery 2. I also tend to load the vehicle heavy with extra gas, etc. I'm curious if the spacers would be helpful. Thanks.
@dcaven Disco's load pretty heavy stock, the bumper's and winch do not really add that much.
The base curb weight with a full tank of gas is 4608 4718 - depending on trim package
Max weight is 6063 - 6228 5 vs 7 seater
So 1455 to 1510 on stock equipment
OEM heavy duty give you +110 lbs
ARB bumper is about 100
A Warn M8000 is 83
So that is only 183 extra
If you are really concerned get full loaded up and go to a truck scale and get your axle weights
Front is 2446 LBS max
Rear 3968 max (7 - seater) 3792 (5 seater)
A Warn M8000 is 83
SundayFunday (07-25-2020)
