Wanted a Disco, but found a Range Rover
I found a 99 HSE 4.6 99K miles its in pretty nice condition with the following issues
Leaking rear bags and the EAS lit on the dash , pump motor is not able to be run from dash switches, though the owner said it pumped up when he started it.
The HVAC display has the book i symbol indicating a need for repair some of the vent selections wont function.
Heated seats dont seem to get warm but the lights come on,.
Tried AC but it didnt seem to work but i was cold outside, I did run the heater first to warm up the cabin
Oil leaking from front timing cover housing oil was 3 qts low, no metal detected after filling and dripping some onto a black piece of cardboard.
Coolant is a bit low now leaks detected inside cabin and block tester stays blue when inserted into the coolant tank
Both elex key fobs missing.
worn tires and a brand new spare .
All wiper blades need to be replaced including headlight wipers
A few other warning on the dash display indicating a problem with the DS front window not setting and a tag light out.
Lots of dog hairs in the aft cargo carpets.
Peeling rubber molding on the RF door seal
Transfer would not go into low range till after about 6 tries then it seemed to work properly
Rear axle seals at the wheels appear to both be leaking
Price in the 5K range, any thoughts.
