Washer Bottle Relocation
4 Attachment(s)
I'm not going to do it like the discoweb sticky. I have something in that place already.
I'd like to stick it in the front of the engine bay, between the battery and the coolant reservoir. . I removed the plastic battery and jack bay and can reconfigure it to fit nicely in there I think. Do I need to worry about engine heat? Should I just cover it in aluminum tape like the chap does on Discoweb? Should I cut my fluid to run a smaller amount of highly flammable cleaner? I think the parts are interchangeable between the D1 and D2 and since I have the D1 system out I might use parts from that. Also I won't be putting in headlight jets so I'll just need the two, windscreen and back window. |
parts arent interchangeable D1/D2. i think i need to modify a standard washer bottle. looking for that now.
2 Attachment(s)
i think im buying the napa 7304514 washer bottle and modifying it. its not very high capacity but it's 100% more than I had before.
the guy iroc on jeepforun (WJ Washer Bottle Relocation Solution! - JeepForum.com) did this: |
