Washer Bottle Relocation
Old Mar 23, 2013 | 12:18 PM
slanginsanjuan's Avatar
Default Washer Bottle Relocation
I'm not going to do it like the discoweb sticky. I have something in that place already.
I'd like to stick it in the front of the engine bay, between the battery and the coolant reservoir. . I removed the plastic battery and jack bay and can reconfigure it to fit nicely in there I think.
Do I need to worry about engine heat? Should I just cover it in aluminum tape like the chap does on Discoweb? Should I cut my fluid to run a smaller amount of highly flammable cleaner?
I think the parts are interchangeable between the D1 and D2 and since I have the D1 system out I might use parts from that. Also I won't be putting in headlight jets so I'll just need the two, windscreen and back window.
Attached Thumbnails Washer Bottle Relocation-20130323_130316.jpg   Washer Bottle Relocation-20130323_130346.jpg   Washer Bottle Relocation-20130323_130400.jpg   Washer Bottle Relocation-20130323_130409.jpg
Old Mar 24, 2013 | 12:15 PM
parts arent interchangeable D1/D2. i think i need to modify a standard washer bottle. looking for that now.
Old Mar 25, 2013 | 02:06 PM
i think im buying the napa 7304514 washer bottle and modifying it. its not very high capacity but it's 100% more than I had before.
the guy iroc on jeepforun (WJ Washer Bottle Relocation Solution! - JeepForum.com) did this:
Attached Thumbnails Washer Bottle Relocation-imag1142.jpg   Washer Bottle Relocation-imag1143.jpg
ggushee
Nov 28, 2023 01:28 AM
RealRitzcracker
Jan 11, 2019 03:19 AM
Zonk872
Jan 20, 2013 03:07 PM
ATXDisco
Jan 18, 2011 12:35 AM
meltdowndave
May 31, 2008 01:10 PM
