Water on Carpet on Passenger Side
Old May 30, 2009 | 09:40 PM
Aj6543's Avatar
Default Water on Carpet on Passenger Side
My passenger side carpet is wet with water. I don't know where the water came from? Some said it was probably water trapped after the rain showers? Any idea? Is this bad?
Old May 30, 2009 | 10:28 PM
Yes it is bad, it will mold if you dont clean it up and dry it out.
Check your A/C drain tubes, crawl under the truck and on either side of the bell housing will be 2 drain tubes, clean them both out.
Old Jun 1, 2009 | 11:37 AM
tango123's Avatar
I had that same problem before too. Check you're windshield seal. I've put some silicone sealant on it and now its not leaking no more.
Old Jun 1, 2009 | 11:50 AM
sloppyjoe's Avatar
9 times outta 10 its gonna be the A/C drains clogged up with gunk.
crawl under the rig. on either side of the tranny housing there are rubber nubs. clear those with a nail or even your fingers.
wear eye protection cause water with gush out. about a gallon will pour out.
cybercop
Apr 10, 2015 07:29 PM
errose2002
Feb 14, 2011 09:31 PM
Spencerfitch
May 3, 2010 02:56 PM
CANAMDiscovery
Aug 5, 2009 02:21 PM
landbeater
Jun 18, 2008 09:05 PM
