Water on the passenger side?
I 've read the posts before this one. I'm new to working on cars and I can not find the plugs for the AC drain. Can some one please be real specific on the exact location of these plugs; a picture or something; I have looked for over an hour. Thanks very much.
Crawl under the truck with a brite flash light, get back by the transmission, look up so you can see the floor curving down from the fire wall. Look on either side of the transmission straight up to the floor, with a good light you should see a nipple on either side of the tranny, positioned so that when they drip, it will run down the side of the tranny case to the ground. take your time, you will find it. Dont' for get to give both nipples equal time when you are squeezing them, don't want to leave partualily plugged.
Mike
Mike
ORIGINAL: lrd99
DISCOMIKE saves the day AGAIN!!
Thanks very mcuh! I went out this morning after reading your messsage and went straight to it.
You Rock!!!!
You Rock!!!!
Mike
Hi All,
So I registered here after my wife noticed water on the passenger side. Was hoping to search around a bit and find some assitance - little did I suspect that it'd be on the first page!
As soon as the vehicle cools down a bit I'll be massaging the nipples
Thanks a ton and talk with you all soon!
alowishus
alowishus
ORIGINAL: alowishus
Hi All,
alowishus
Hi All,
alowishus
Mike
bigbadbannana
Dec 15, 2007 06:26 AM
