Water pouring into passenger footwell!
Old 09-12-2020, 11:08 AM
Tony Luna's Avatar
Default Water pouring into passenger footwell!
New windshield, lower cowl, A pillar moldings, sealed upper rain trim areas inside and out, and new headliner. Installed a new(er) dash and did the blower fan service a few months ago.
At the car wash this morning and I notice water free flowing into the passenger footwell. The cover below the fan assy is off and the water seems to be coming off the lowest point of the fan - gushing!
The amount of water leads me to believe it wil be something obvious - once I find the hole.
any ideas/clues?
Thanks in advance,
Old 09-12-2020, 11:21 AM
nashvegas's Avatar
Received 1,252 Likes on 672 Posts
Check this area. You can easily test -- what you're looking for is water getting in AROUND the air intake. I'd bet that's it. It can also get in straight through the air intake but if you have a new cowl, it should be fine. If the cowl is installed incorrectly or cracked, water gets in right through the air intake.
Old 09-12-2020, 12:24 PM
Tony Luna's Avatar
Thanks for the prompt response! I’ll be sure to check that first thing.
Old 09-13-2020, 04:49 PM
Tony Luna's Avatar
Took the cowl off. Sealed around the inlet base with RTV and added some marine weatherstripping. Dry as a bone. Don’t really like the way the seal on a brand new cowl bows in a couple of spots and loses contact with the windshield - it was like this before the weatherstripping too. If I push the cowl as far up as possible, the seal does flatten out, bun theN I’m afraid of too much pressure on the engine bay seal when the hood is closed.
Old 09-13-2020, 07:05 PM
nashvegas's Avatar
Heads up that little push-in fastener you're using on the cowl isn't the right one. I have no idea if water is leaking through it just a slight bit too, but .. here's the correct one:
AWR3994 - Scrivet - https://parts.jaguarlandroverclassic...?code=L5C01050
JYF100190 - Plastic Washer (goes under the cowl between cowl and the metal support bracket) - https://parts.jaguarlandroverclassic...?code=L5C01050
You'd need 2 of each.
These washers are missing on 99% of Disco's btw
Old 09-13-2020, 07:42 PM
Tony Luna's Avatar
Awesome - thanks for the heads up!
Old 10-09-2020, 01:19 PM
Tony Luna's Avatar
Round 2 knocked the issue out for good!
Ordered some edge seal from Amazon and installed around the upper edge of the fan intake.
Tested with garden hose at full throttle.
Done!
The following 4 users liked this post by Tony Luna:
Best4x4 (10-09-2020), JohnZo (02-11-2022), JUKE179r (11-06-2020), Richard Gallant (10-09-2020)
Old 10-09-2020, 02:54 PM
stillruns's Avatar
That’s the best idea for that fix I’ve seen. What’s the part number for the edge seal?
Old 10-09-2020, 03:00 PM
Tony Luna's Avatar
Min order quantity was 10 feet. PM me your address - I'll send you a piece.
Old 10-09-2020, 03:31 PM
Richard Gallant's Avatar
Received 1,177 Likes on 814 Posts
Brillant ! that is the best solution I have seen yet
Quick Reply: Water pouring into passenger footwell!
