-   Discovery II (https://landroverforums.com/forum/discovery-ii-18/)
-   -   Water Pump Gasket (https://landroverforums.com/forum/discovery-ii-18/water-pump-gasket-59347/)
Colorado David May 25, 2013 09:22 PM
Water Pump Gasket
Do I use gasket sealer or not?
mln01 May 26, 2013 12:37 AM
Gasket sealer is not needed, but you do need to use thread sealer on the longer bolts.
Rover_Hokie May 26, 2013 12:39 AM
I used just a thin layer of gasket sealer applied to the water pump surface to hold the gasket in place while working, and I used the same gasket sealer on the bolt threads.
Disco Mike May 26, 2013 08:47 AM
I like doing it as Tony mentioned.
Also make sure to change out your t/stat and coolant pressure cap at the same time, use a 180 degree soft spring t/stsa for better cooling.
Colorado David May 26, 2013 09:47 PM
Done. I had to shorten the t-stat to water pump hose by about half an inch to get everything to seal up properly.
Bryan H May 27, 2013 12:56 PM
So do you guys put sealant on all the bolts? Rave doesn't mention that step in the pump installation instructions. Do some of the bolts actually enter block coolant passages? That seems like a terrible design.
Colorado David May 27, 2013 10:28 PM
There are short bolts and long bolts. I did have coolant drain from the long bolt holes. There are also two socket sizes. The short bolts are all 10mm and the long bolts are 11mm.
Bryan H May 28, 2013 07:05 AM
Good to know. I'll take a look at mine.
