Water Pump Gasket
Old May 25, 2013 | 09:22 PM
Colorado David's Avatar
Default Water Pump Gasket
Do I use gasket sealer or not?
Old May 26, 2013 | 12:37 AM
mln01's Avatar
Gasket sealer is not needed, but you do need to use thread sealer on the longer bolts.
Old May 26, 2013 | 12:39 AM
Rover_Hokie's Avatar
I used just a thin layer of gasket sealer applied to the water pump surface to hold the gasket in place while working, and I used the same gasket sealer on the bolt threads.
Old May 26, 2013 | 08:47 AM
I like doing it as Tony mentioned.
Also make sure to change out your t/stat and coolant pressure cap at the same time, use a 180 degree soft spring t/stsa for better cooling.
Old May 26, 2013 | 09:47 PM
Done. I had to shorten the t-stat to water pump hose by about half an inch to get everything to seal up properly.
Old May 27, 2013 | 12:56 PM
Bryan H's Avatar
So do you guys put sealant on all the bolts? Rave doesn't mention that step in the pump installation instructions. Do some of the bolts actually enter block coolant passages? That seems like a terrible design.
Old May 27, 2013 | 10:28 PM
There are short bolts and long bolts. I did have coolant drain from the long bolt holes. There are also two socket sizes. The short bolts are all 10mm and the long bolts are 11mm.
Old May 28, 2013 | 07:05 AM
Bryan H's Avatar
Good to know. I'll take a look at mine.
outdoor7or24
Dec 22, 2014 09:31 PM
myall200
Nov 23, 2008 10:39 PM
Fonzie
Nov 10, 2007 09:29 PM
wellerdoug
May 12, 2005 05:22 PM
