water pump leaking at weep hole
Old 04-22-2008, 09:01 PM
Helper's Avatar
4th Gear
Default water pump leaking at weep hole
We have replaced 2 water pumps that were leaking at weep hole. After 30 min. driving there would be a wet spot about 1 foot in dia. where it was parked. The second pump .has only been on 30 days
Old 04-22-2008, 09:07 PM
Default RE: water pump leaking at weep hole
So what is your question?
Old 04-22-2008, 10:54 PM
okdiscoguy's Avatar
year and mileage of the truck? Where did you get the pumps from? How much did you pay for it?
Need more info to help....
Old 04-23-2008, 07:46 AM
Are you using new Rover replacement water pumps or aftermarket?
Old 04-23-2008, 09:04 AM
tee51397's Avatar
You are sure the spot is from the pump/coolant and not from the condensation drain for the A/C right.
Old 04-23-2008, 07:35 PM
Helper's Avatar
4th Gear
My question is why would a pump only last 30 days and one lasted 180 days
Old 04-23-2008, 07:41 PM
Helper's Avatar
4th Gear
Yes it is coming from weep hole
Old 04-23-2008, 07:46 PM
Either the belt is to tight and it is causing the bearings to wear prematurely, not likely but possable, most likely is just bad pumps.
I imagine that the first one that you bought had a warrenty and the replacements were given to you under warrenty. If that is the case then you need a different brand of pump.
Dont get a replacement, get your money back. What brand of pump did you buy? The rest of us need to know so that we dont buy this brand.
Old 04-23-2008, 08:13 PM
Helper's Avatar
4th Gear
02 model original pump locked up at 75K miles Ford dealer replaced pump don't know brand it lasted 30K We replaced it with Proline pump from Rovers North it lasted 9K Before installing last pump (warranty) we flushed system and installed new coolant Dexcol (orange) this pump has only lasted 3K. Rover North said they have not had any problems with these pumps and they are willing to give money back toward purchase of OEM Pump. Proline pump cost $90
Old 04-23-2008, 08:19 PM
I have heard from other forums that the Proline pumps are bad and Rovers North told them the same thing. They got their money back and used it towards a LR pump.
Get the OEM pump, note to self, dont buy a Proline water pump.
Quick Reply: water pump leaking at weep hole
